Engine hatch
bill46
C-302 SC
FMLT3107F314
Radio Active
Engine hatch does nor raise with switch. R31CB, pump runs, tabs full up, looks like there is fluid, pump changes pitch when tabs reach end. No action on hatch, all 3 tubing connected. Any ideas?
the solenoids on the valve assembly could be shot. im having the same issue and replacing the whole unit. its a custom part on the hydraulic hatch boats as the valve assembly drives both the trim tabs and the hatch. Cutwater had bennett make the part. talk to Ronnie at Ranger/cutwater.
Fixed Hatch lift. Dummy had tabs down instead of up!
