Engine oil VP D4
trailertrawlerkismet
(2022) Kismet
Our D4 Volvo Penta manual lists Volvo Penta SAE 15W40 API CJ4 for the diesel engine, based on what I wrote down. I do not have my manual with me to check other approved brands and am wondering what other equivalent others have used when changing the engine oil???
Jim Favors
During my first D4-300 service, the certified Volvo mechanic used Delo. Unfortunately, I don't recall the exact specs of the oil.
However, you should be able to download a copy of your manual from the following link if you want to see what the manual states:
http://www.volvopenta.com/marineleisure ... books.html
Rotella T-6 is synthetic. Rotella T-4 is standard heavy duty diesel oil. I have used T-4 because I was told that synthetic was not recommended until the engine has 500 hours. I went with that suggestion and have used T-4. Is there any knowledge of this statement? I asked the Volvo technician at the marina about this. He wasn't sure , "We are a Volvo dealer and use OEM Volvo 15W/40 diesel oil which is non synthetic. VDS-3, Volvo Drain Specifications, API SL, CI-4" in the past. The last year or so we changed the oil to Volvo OEM VDS-4, API CJ-4, and ACEA E9. Still non synthetic. Both Rotella T-6 and T-4 meet the same specs.VDS-4 and VDS-4.5 API CJ-4.
