Nellie Too
- Jan 13, 2009
- C-288 C
- (2009) Nellie Too
Hello All,
A few weeks ago I was coming home and the engine warnings came on, the temp was showing 225'. I had the fresh water impeller replaced (which had been quite damaged) and also refilled the antifreeze. After all was done I became very attentive to operating temp and am very concerned about it. I am wishing to get some feedback about your normal temps so that I can compare mine. Currently at 1200 rpm it operates at 200', at 2200 rpm the temp rises to 205' and if I run it to work the turbo at 3600 rpm the temp rises to 213' ( think this is quite high and I am concerned). I called MER Equipment to price a new thermostat (comes as an assembly) the price is $137.00 but they said I could have it a $117.00. It appears that this is a seldom needed item because they only had 5 at the Chicago distribution center. I plan to dive under the boat to check the seawater intake to make sure it isn't partially plugged but the water is quite cold at this time. Any input would be appreciated.
Bob
Bob
