I have a 2026 Ranger Tug 27. I have had the boat in the water for about 4 weeks in the northeast. Initially when I turned on the reverse cycle heater it would run for about 45 minutes before shutting down and giving me an error message, F2. The problem has worsened and now when the heat cycle is turned on the pump will run (its audiable) but no water exists overboard from the unit and it will eventually shut down, giving the same error message, F2. The strainer is clear. When I disconnected the hose from the thru-hull to the pump water came in. It is highly unlikely that there is a blockage at the intake end. The water temp is above 45 degrees F so I don't think its a heat/energy problem. Thoughts?
tks
Rick
tks
Rick
