Capt’nKarl
- Feb 22, 2013
- C-242 C
- FMLT2330I718
- Non-Fluid Motion Model
- Previous R-21EC
- DRAGONFLY
After additional investigation into the malfunctioning AC system on my 21 EC I found the following. The thru hull for the AC system is patent, the raw water strainer is open and clear. The AC water pump worked flawlessly (I removed the unit and connected it to power). The blower blows and there is condensation on the coils so I think the compressor is working BUT when everything is connected and I turn the unit ON with the temperature set at 60 degrees (Temp inside the cabin is 70) the water pump does not work. All the electrical connections are tight. I've done all I know how to do. Does anyone have any suggestions? I would appreciate any feedback.
Karl
Karl
