First time wiring question
Sean farrell
Hello All
First time wiring a boat. I am trying to install a new portable live well pump on my Cutwater 24. Should I run the wiring up to the fuse panel located behind the controls in the head or is it OK to just wire the live well to the switch and battery with an in-line fuse? From a quick look it seems like there is a harness of earth connections next to the charger, but all connections for positive and negative go up front.
If the best & safest approach is to run the wires up front, what is the path and how do I get access? The layout of the C24 is basically the same as the R23 I believe.
I’d prefer to do this right and not a fudge, particularly as it’s a gas I/O.
Sean
Hi Sean,
Without knowing the current draw or even if its a 12v dc system. What I would do is get a Scotty male plug and adapt it to the portable live well and use your prewired down-rigger plugins . That is if your not using the down riggers at the same time. Other wise there is a fuse panel in where your inverter is and there are a few spare fuse holders available. Hope this helps
Tim
