You can save some cash, and have some fun by sewing your own Fender Covers
Fleece is soft, durable and does not cause fender rash. I sewed up a set of dock fender covers and boat fender covers last year to try them out. They worked very well and did not mar the sides of the boat. The key is to spray them off whenever you are washing off your boat to wash out the salt and dirt that accumulates in the fleece. I tie my permanent fleece dock fenders horizontal to the dock to lessen the surface area rub on the hull.
Fleece fender covers are also available commercially.
Department stores like Walmart have cheap usable fleece fabric. Parachute cord or heavy duty nylon cord is available in hardware stores. Stretchy 100 percent polyester thread is available at most fabric stores
Cut the fabric to size, sew one inch casings on either end and run the nylon parachute cord through the casings. Leave about 7 inches of cord on either side of the casing as a pull cord and tie off area. Sew the side seam. I do two seams on each line of stitching for extra strength. Turn the fender cover right side out and pull it over the fender. Tighten up the nylon cords so it pulls over the top and bottom of the fender. Knot the cord with an over hand knot and tuck the ends under the cover. Make sure you have enough fabric to cover the ends of the fender so it does not ride up on the fender during use.
Good luck with your fender covers
PUFFIN R-29 PORT TOWNSEND WA
