Force 10 Solenoid Question
Bob&Jilly
Fargher Lake WA
FMLT2757*818
Lynnsanity II
If you had to replace the solenoid on your force 10 stove line did you need to cut the wires on the existing solenoid and splice in the new one? Is there any way to check the solenoid without cutting the wires?
hope this helps answer your question Bob
Thanks, how do you disconnect the wires?
You should have a splice on the wires usually a butt connector, I would cut the wire there and be sure to have new ones available for reconnecting.
