dpiano
- Jul 16, 2011
- C-288 C
- Spindrift
Our new 29 Ranger gave us an exciting moment several weeks ago. We were out of the country for a few days, during which we had a rare spell of freezing weather in Portland OR, down to about 12F for a couple days. I had low electric heat on in the salon with the engine room hatch open. After returning I checked on the boat and found water pouring out almost steady from the bilge through-hull. Very exciting! In the engine room water was pouring in from under the white step beside the prop shaft. I shut off the raw water valve, but water continued to pour in. Even more exciting! I called Ronnie (he answered, bless his heart...... 8:30pm on a Thursday eve) and he helped me through the crisis. The deck wash pump had apparently frozen enough to break the clear plastic cover on its strainer and river water was gushing in, draining into the well under the stern thruster. That well has a drain molded into the hull which empties under the white step. There was enough water built up in that well so that it took some time for the flow to stop after I shut off the raw water valve. Also I later discovered the cockpit sink was running a steady stream of water when the fresh water pump was turned on. Turns out there is a little ceramic disk in each faucet which cracks when frozen, though the line was not pressurized during the freeze.
The factory is great; they are sending a couple of pump strainers, and a new cockpit faucet on warranty. Obviously I need more heat in the engine room. But it seems to me that, with the deck wash pump located below water level, the boat is dependent on the integrity of that strainer cover and is therefore a rather weak point in the boat's safety. Ronnie suggested closing the raw-water valve when away from the boat which is no doubt a good idea. Beyond that I think it's prudent to install ballcock valves with a freeze drain on the lines for the deckwash pump and cockpit sink, which I have done. We use the boat year-round and these valves will let me sleep better at night in cold weather.
