Subject: Fresh water accumulates in aft bilge in my new R-27/OB
This issue has been ongoing ever since owning my R-27/OB. It bothered me to the extent I asked RT factory to check this issue out when it was taken back to the factory for some other post assembly work. They presumably did a thorough job with spraying the boat down in some manner to see if there were any leaks and none were found.
The boat is kept in salt water and today I examined the aft bilge only to find at least a 1" deep fresh water sitting there. The 1" is insufficient to activate the auto bilge pump. A few weeks ago I had gone to the trouble of completely removing all the fresh water from this section of the bilge to the extent it was bone dry. The idea was to see whether more fresh water would accumulate in this bilge area. For two weeks I checked now and then and this bilge area remained bone dry.
Today after some weeks of last checking I checked this bilge area again and found 1" of fresh water there.
Where on earth is this coming from I asked myself ?
1) First, it's fresh water and not salt water so this water is not coming through the hull or hull ports and no-one as far as I know is spraying salt water on the boat.
2) For past week its been raining quite hard with plenty of wind about.
3) My boat is in a covered slip with bow in.
4) The aft end of the boat is covered vertically by the dock's roof but is exposed to rain that can fall onto the very aft section of the transom if windy. This is noticed as the top surface of the grill cabinet is wet with rain droplets.
5) I began my search for the fresh water entrance to the bilge area by looking into the very aft area of the cockpit's center locker. There's a bulkhead at the aft section of this locker that the ski tow bar is bolted to. This bulkhead has a 3/4" seep hole at its base to allow water aft of this bulkhead to flow into the bilge. I place my hand and down into this aft section that extends back to the well in the rear platform that the F300 engine is bolted to. I found water there and gently splashed it toward the seep hole and sure enough water flowed through into the bilge where the through hull port is that feeds salt water to the wash down pump and the toilet. Hmmmm, could this be where the fresh water is coming from ? If so, how does the fresh water get into this very aft section ?
6) I checked the transom well where the hydraulic lines exit to then goto the engine steering mechanism. This well has its own drain and had just a smattering of rain water in it. I don't see that any water in this well could make it into the very aft section I describe in 5) above.
7) I now looked closely at the ski tow bar's bolted base plate on the bulkhead and noted drops of fresh water were on the bulkhead surface and some on the ski tow bar's base plate. Hmmmm, could rain water falling onto the retracted ski tow bar on the transom allow water to flow down to the bilge area.... I think at this time it's possible.
8) As there were plenty of rain droplets on the top surface of the grill cover I also wonder if rain water running off this surface could somehow make its way down to the bilge. To find out I raised the grill's cover lid to force the rain droplets to flow backwards and off to the water gutter at the cover's hinge area. I then looked into the cockpit's center locker and at the base of the ski tow bar's bolted plate and sure enough saw some new water droplets on the base plate.
So now my guess is that rain falling on the aft section transom area can find its way down to the very aft area of the cockpit's center locker and that this water can end up in two places; one being the very aft section behind the bulkhead that the ski tow bar is bolted to and more directly into the very aft section of the center cockpit's locker and forward of the bulkhead that the ski tow bar is bolted to and where the auto bilge pump is located.
I'm not that worried about this fresh water accumulation at this point as the aft bilge pump will take care of it if the level gets much above 1". However, if the boat's aft section is exposed to rain I will have to expect that it will find its way into the bilge. Thus, anything I care to stow in the aft section of the cockpit's center locker best be something that is not affected by water; such as a couple of larger fenders. With two larger fenders in this section I can place other stuff and be comfortable they will not get wet.
For other R-27/OB owners I would ask if they also are seeing or have seen the fresh water accumulating in the aft bilge and if so, what are your thoughts about the reasons for this as I mentioned here ?
Thanks.... 🙂
Thanks.... 🙂
