Rick & Karen
- Nov 23, 2008
- C-24 C SE
- FMLT2142J607
- Kolo Iki (Little Tug)
Good Evening All,
For those of us who operate our tugs in salt water, I learned a neat preventive maintenance tip yesterday while attending the Diesel in a Day course. The instructor, who works for the Yanmar dealer on island, said that heat exchangers and related cooling system components are one of the weak spots he sees when having to make repairs on engines that are overheating or have failed. Eventually the liner or mini radiator inside your heat exchanger will start to plug up and restrict the flow of cooling water. If you are lucky, the liner can be sent to a radiator shop to be boiled out and reinstalled. Anyway you look at it however, you will be spending a considerable amount of money making this repair. He showed the class a cast iron U-joint that is found between the heat exchanger and discharge hose that had almost closed up due to corrosion. The salt crystals that stay inside the heat exchanger every time you run the engine on your tug will accelerate this process.
To defend against this rather insidious process, our instructor said that some boat owners will install a valve or fitting that will allow them to flush out the raw water cooling system with fresh water. To my pleasant surprise, after studying the 8"x10" photos of my engine that I brought with me for reference, I realized that this feature was already installed on my boat. The R-21EC owner's manual makes a single refence in the to this feature on page 27 under Engines in the Winter Storage Checklist. It says to:
Flush sea strainer system with fresh water.
Now I apologize for perhaps pointing out the obvious to our more experienced boaters, but I did not make this connection until yesterday. We were told that if we flushed out the cooling system after every use, the corrosion process, would be severly curtailed. I tried it that evening after taking Kolo Iki out to secure the prop zinc and it worked exactly as described in class. I have never seen this issue addressed on this site or the C-Brats site so here are the (safe) steps for those that will want to try this on their boat:
1. Close the seacock to the sea strainer.
2. Unscrew the black cap on the T fitting installed immediately downstream of the sea strainer. A small amount of water will dribble underneath the engine and flow into the bilge. Attach a short section of hose to the threads on the fitting.
3. Fill a bucket up with about two gallons of fresh water and leave the running hose in the bucket. Place the end of the other hose you just screwed into the fitting in the bucket as well.
4. Start the engine and make sure that water is being drawn into the cooling system and discharged over the side.
5. Let the engine run for about five to ten minutes and then shut it down. Unscrew the short hose from the fitting, put the cap back on and you are done except for tidying up.
You can attach a garden hose directly to this fitting and not use a bucket, but I would caution against doing so with the following note.
WARNING: Do not attach the hose from your hose bib directly to this fitting and turn it on before starting the engine. Doing so may backfill the engine with water.
Personally, I prefer procedures that won't damage anything if I do something out of sequence.
The evidence presented in class made a believer out of me and I intend to flush out my raw water cooling system after every outing, just like you see people do with outboard motors. It only takes a few minutes and the potential cost savings and lack of downtime are significant.
Aloha,
Rick
Aloha,
Rick
