BB marine
- Feb 1, 2016
- C-26
- Non-Fluid Motion Model
- Grady White 208
- PORT-A-GEE
This is my first year dealing with my C26 D3 Volvo 220 hp operating in salt water. I wanted to keep the engine compartment looking new, internal raw water cooling system clean, and head odors to a minimum. I made a couple of changes to the boat to accommodate this.
(1) Removed the raw water flush hose from the Marine Hardware sea stainer port and installed fresh water flush for the head.
(2) Installed a ball valve at the Marine Hardware sea strainer port ( old head raw water port). At the end of the ball valve is a Garden hose fitting that a 7/8 reenforced flexible hose attaches to. At the end of a day of cruising if we are in a marina and tied up I top off our water tank and then fill a 3 gallon pail that I have on board with fresh water and put the hose in the pail. I attach my 7/8" hose to the ball valve attached to the strainer and place the other end in the pail. I start the engine, then open the ball valve. I let the engine run for about a minute and close the engine seacock. The water for raw water system is now being pulled from the pail flushing the complete raw water system. I run the engine for about 5 minutes and then shut it down. I then close the ball valve and place the engine keys on the handle of the seacock so I am reminded to open it before starting the engine . My engine is fully flushed and sits with fresh water in the raw water cooling system. Using this method I never spill salt water in and around the motor mounts, My stainer looks shiny new, If I need to clean the stainer I have fresh water in it.
(3) Shaft packing shield installed over the packing gland to deflect all spray down into the bilge and not up which leaves a fine mist of salt water coating the engine compartment. This shield has worked better than my expectations. It is made of a .090 thick vinyl material and snaps in place. After a 1.5 month period last fall and 3 months this winter cruising in Florida waters there is no evidence of tarnishing of the packing gland , rust at the mounts or salt residue anywhere in the compartment.
(1) and (2)
Fresh water hose install and rerouting of waste hose to take the kink out. I made the hole larger and removable cover for easier access to head plumbing.
gallery2.php?g2_itemId=66749&g2_imageViewsIndex=1
gallery2.php?g2_itemId=52085&g2_imageViewsIndex=1
(3)
gallery2.php?g2_itemId=70774&g2_imageViewsIndex=1
gallery2.php?g2_itemId=70777&g2_imageViewsIndex=1
gallery2.php?g2_itemId=70780
When doing my 100 hr servicing yesterday I was happy with the results seen from these changes. I can say there is no evidence in the engine compartment of this boat being operated in salt water. Looks like the day we took delivery!
(1) and (2)
(3)
