Fresh water guage
ftornabe
R-25 (Outboard)
FMLT2535A121
Sea Wolf
Hello,
The fresh water gauge stopped working on my 2021 R25 Tug. I have voltage at the gauge so I can eliminate wiring issue. Wondering if replacing the gauge will fix it. As anyone had this problem and what brand gauge did you use?
Thanks!
Does the voltage change w/ differences in tank level?
The needle is stuck on empty. I haven't checked the voltage at different levels. The fact that it's always on empty lets me believe not the sender.
It's possible the float is stuck. I had to replace the gauge, which isn't difficult. Worked great ever since.
our gauge was stuck on full once. We banged the side of the water tank with a large wrench and that unstuck the float. Maybe give that a try. Hopefully it's an easy fix.
What size was your guage? Mine is 2" diamete. And what brand did you replace it with?
