Fresh water hose hookup
kjoverbeck
FMLT2704E415
Cheers
2015 R-27
There is no freshwater hose connection on my boat in the location shown in the manual.(midships, starboard side)
I have not been able to locate one. Does anyone know of it's location?
Thanks, Kent
Fresh water dockside connections were eliminated at sometime, probably shortly before your boat was built.....that’s why you can not locate it. We had one on our 2012 R27 but not our 2018 R29S.
Jim
Those dock side water connections were eliminated for a very good safety issue. As the boats get older the internal plastic hoses get brittle. If you left the dock water hose pressure on at the boat fitting and a hose inside the boat failed it could sink your boat. All-in-all those fittings were a significant and unnecessary risk. We have one on our boat that will NEVER be used!
Well, that takes care of that!
Thanks Guys, Kent
And it is no inconvenience as well as you always have fresh water in your tank.
Hello kjoverbeck, as others have mentioned we stopped installing the dockside water fittings prior to when your boat was built.
Thank you,
-Tim
