Fuel filter change then check engine alarm
Brian B
C-26
FMLR2512L910
Sold in 2021
GANSETT RANGER (2010) Yanmar 4BY2-150
Yesterday a Yanmar tech changed out both fuel filters on my 4BY2150.
I had ran the new to me boat about 5 hours previously on two separate days without any issues.
The system was bled according to the book and when it was started the engine alarm goes off and the display reads check engine. Immediate shut down, everything rechecked, restart and same alarm. Tech is guessing that it may have something to do with the water sensor in the primary filter that was disconnected. He later ran the codes in the system and it read #1 glow plug. As he went through different procedures the alarm would be intermittent. He was quite perplexed as what was going on, while I'm thinking a major repair coming my way. He located the culprit, unplugged it, plugged it back in and all seems OK now. After numerous restarts no alarms.
The shop manual states the water sensor would not leave a code.
Had I done this filter change myself and had the alarm blaring I would have been in a real tough situation, when it comes to electronics I'm at a loss. The boat would then have to be taken in for service, maybe towed, not knowing what was wrong and then pay over $90.00 per hour for diagnostics and repair.
Exactly what caused this we do not know at this time.
I will have 2nd thoughts about doing a filter change myself in the future. Perhaps it was just a coincidence but there were no problems at all before the fuel filters were changed.
Weird...... The 4BY2-150 does not have Glow Plugs. The engine is setup for them but they are not installed.
Yup that's what the tech said.
I am just guessing but lots of legacy error codes are in software systems that are never removed from earlier systems. Many times the same error code flags generate inappropriate screen error information, at least this is true of software programming languages. If you wanted to be sure, you could unplug the water sensor and try to duplicate the same startup procedure to try to reproduce the same error, or you could just hope it never happens again and chalk up up to Yanmar unknowable mysteries of which there are many. Just feel happy you were not on the water.
Brian,
Don't let an alarm intimidate you from doing work yourself in the future. My theory is know your limitations, if it is broken try to fix it yourself and you may learn something and when you bring it for repair after you broke it more watch and learn! Education isn't cheap, but life experience is the best learned lessons.
Mike: Very true... When I'm compelled to hire a technician I watch every move they make and learn from it. The same is true from reading what others here state they've done to resolve some kind of issue with their boats.
