ohioan55
- Aug 25, 2015
- R-23 (Outboard)
- FMLT2314C424
- Jersey Girl
I have an issue after swapping out the fuel filters with priming the system. I started venting the fuel lines/filters using fuel hand pump and vent nut. About half way through the process, the hand pump started acting funny and not returning to the outward position after being depressed and then released. I even left the vent open to see if it was somehow bound up with pressure or vacuum. Well, I can not finish venting the system. I checked the secondary fuel filter and it is only have full. The fuel valve is open. I'm not sure if I'm missing something or has my manual prime pump failed? Any insight would be appreciated.
