BB marine
- Feb 1, 2016
- C-26
- Non-Fluid Motion Model
- Grady White 208
- PORT-A-GEE
I send my oil samples out after each oil change, engine oil and reverse gear. I Started after the 50hr break in oil change. I now have 324 hrs on the engine and 4 oil changes. Each oil change sent out for analysis. Except for first 50 hr no oil report because it was break-in. 2nd, 65 hrs (125 engine hrs) 3rd, 109hrs (134 engine Hrs) 4th, 92 hrs ( 326 engine HR). I now have a small amount of reports to set up a trend for my D3. For the most part all wear metals have been in range using a universal averages. All on the high side of the averages but with in range based on the comments provided by Blackstone Labs. My last oil analysis came back with a increase in wear metals, the two that increased the most were Iron and Copper. Iron was 40% more PPM and Copper was 30% PPM. When I read this report I was surprised. Last oil change (109 Hr) had 15 hr more hours of run time and the oil sample came back stating this was a good oil use interval.This oil analysis came back saying its time to change the oil. What changed ? I called and talked to the Lab and the question was asked did you change you running conditions on this oil interval? Yes I started running at a higher cruising RPM more often and for a longer period of time. That was my answer of why! Last year I decided to run the engine at a higher RPM (3360 approx.70% load) to increase our cruise speed to 13Kts. I keep a ship log which has all fuel consumed recorded. I looked at the difference in fuel usage from last oil change to this oil change. 109 hrs, 281.8 gallons of fuel used, average fuel usage was 2.57 GPH. Present oil change 92hr, 386.87 gallons used, average fuel usage was 4.2 GPH. Based on this I'm going to use 300 gallons of fuel as my base line for oil changes. If my average cruising fuel consumption is approx 2.5 gph I'm good for 120 hr oil changes. If my average is approx 4.2 gph I'm good for approx 71 hrs . I realize I'm over analyzing this ! I worked in reliability department for to many years :shock:. Many articles about diesel engines state Hrs of run time is irrelevant to the engines life expectancy because it doesn't take usage of hours into account. Gallons of fuel used is a more accurate way to determine life expectancy of a diesel power plant. Why not use this same theory for oil change intervals while cruising?
