Fuse location - salon outlets, starboard
LeGeMar
C-288 C
FMLT2915K415
LeGeMar
The 110v salon outlets, starboard (the one under the galley table, the other in the rear berth) went out. I tested every fuse but obviously missed one. Which one is it??? I have the fuse chart onboard, but some of the labels are confusing.
Apologies if pointing what you already know but I would think you would be looking at the breaker panel for a tripped breaker. I think all the fuses are for the 12V wiring. Not sure if there are any GFI plugs installed but that would be the other issue I would investigate. If there are any I would think they would be in the bathroom or by the kitchen sink.
Assuming that you were using the inverter and not shore power, I had a similar problem. All visible fuses and circuit breakers appeared to be OK, but the inverter wouldn't turn on. The problem turned out to be what I couldn't see. By reaching up through a hole near the entrance to the cave, I could feel the completely hidden inverter. Exploring the area more with my fingers, I located what felt like a GFI reset button. Pressing it resolved the problem.
Marshall
Hello,
There are no fuses for the 110v outlets. They have re-settable breakers on the AC panel. Since its only the starboard outlets I would try re-setting the GFI itself, it would be on the outlet in the head there is a reset button right in the middle. Hope this helps!!
Thank you,
Kevin Lamont
Thanks for your comments and clarifications. It was the GFI.
