Fuse question?
Rebel112r
North Pacific 42(SOLD)
Rogue
Is the Fusion stereo on the same circuit as fridge? Was winterizing and had fridge fuse pulled and noticed Fusion would not work…. Next, where is fuse that will remove power from propane sensor and solenoid? This is for a 2021 R27. Thanks
Grab the manual from the web. Shows fuse blocks well. The propane sensor/solenoid fuse is in the "always on block" with bilge pumps, co, stereo memory, etc. small block located behind the small wood panel at the right base of the electrical wall just inside the cabin door in the cave.
Thanks, that is now taken care of.
