Fusion MS IP700i
JeffreyAC77
2015 R31-CB (LE)
Lake Union, Washington
R-31 CB
FMLT3106E415
State of Mind
My unit in the v berth is locked "on". I have a 2015 R31-CB luxury edition. Fusion recommended that I detach the unit from the rear power cable (not just pull the fuse) for a period of time. When I detach the unit from the wall, the cable isn't long enough to pull it totally out to access the power cable. My question is - is there enough cable to remove the unit from the wall or is my cable possibly hung up somewhere? Any suggestions would be appreciated. thanks.
Hello,
There should be enough to remove the unit, most likely what's hanging you up is the service loop in the harness behind the stereo. You can remove the inside walls of the big vberth closet and access the area behind the head unit. Some of our customers will put in a cabinet below the vberth tv to gain access and storage. If you're interested you can reach Tim in parts at parts@rangertugs.com and he can sell and ship you the cabinet and frame. Allow sometime for us to make the cabinet and frame. Hope this all helps.
Thanks,[/quote]
Kevin,
Will this cabinet work on a 2012 29' ?
Katmat":2jz9t3i2 said:
Kevin,
Katmat,
Yes this should work in the classic R29, on both models you may need to raise the vberth tv mount up a bit. Typically we install these before we install the tv and stereo head unit.
Kevin, Do you have a photo or drawing of the additional cabinet?
Hello,
Currently I don't have any pictures of the extra storage cabinets. I will try and get some and post them here for you, there maybe a customer reading this that has the option that could get them faster.
JeffreyAC77, I can send you some pictures of the additional cabinets that Kevin installed on my R31CB however, I don’t know how to upload photos to this forum. Perhaps someone could advise.
Getting a User Photo Album is easy but it requires submitting a request from within the site structure.
1. Sign on to the site.
2. Select the User Control Panel link from the upper left corner of any page. Note: On the home page, this link is in your user menu in the upper right.
3. Click the Usergroups tab, then select the radio button next to the User Albums group.
Scroll down, choose "Join selected" in the drop-down menu, and click the Submit button.
Once you do this, an email is automatically sent to the administrator (me). That message will trigger my ability to approve your request, and you'll receive an email indicating your membership in the UserAlbums group has been activated.
There are two ways to embed images in your posts.
If the picture you want to include is in one of your gallery folders (on Tugnuts), click on the g2Imgbutton. That will open another window which will allow you to browse your galleries and select a picture. Be patient, it can take a while for the new window to populate. It should default to your album when it opens.
Click the box in the upper left of the picture you want to post. Scroll (way) down to the bottom of the window and click Submit. That will attach the picture to your post.
If the picture isn't in your gallery, perhaps something you've seen elsewhere on the web, or in another personal web collection (i.e. flickr, iCloud, google, etc.) then you click the Img button. The image/collection must be open to the public.
This will create the following string in your posting window - then you copy and paste the URL (http://whatever...jpg) of the desired image in the middle, between the ][ brackets. The trick here is to determine the direct URL of the image. Various image hosting sites show it in different ways. Sometimes it's right up in the address bar. Other times it's listed under "Share This Image", etc.
You can determine if you have the correct URL by hitting the Preview button. If it displays, you're good to go. If it's not correct, the form will give you some kind of clue so you can go back and dig around. You'll only have to figure it out once for each host.
I'll watch for the message, and look forward to seeing your pictures.
Cheers,
Bruce
Can you post images of the cabinets open?
Ctcomtx, yes I will be down at the boat tomorrow and will take more pictures with the cabinet doors open.
