Fusion Radio Locking Up
OverTime
PNW South Sound
R-29 CB
OverTime
The fusion system on our boat works well EXCEPT that the FM radio likes to "lock up". When this happens, I lose all control over the system, I can't even turn it off, I have to pull the fuse. It is hooked up through the Garmin Chart plotter but that can't control it either when it's in that state. The Fusion rep at the Boat Show didn't have a ready answer. Anyone else ever have this? Thanks.
I cycle the house power switch for 15 seconds and it seems to resolve the Fusion radio issues. As they love to say in my IT department: "did you reboot it"?
Is that the same as pulling the fuse? Sometimes it will play for hours no problem, other days, it is useless for radio.
There are certain software versions of both fusion head units and Garmin plotters that are known to not play well together and cause locking up issues. Also some models of fusion head units can experience locking up issues sometimes from bad hardware straight from the factory (common on ra70, ra70n, ra70nsx), or bad original software in the case of early ra770's.
Most often it's related to issues with the nmea2000 network such as incorrect drop lengths, incorrect number of terminators, multiple power sources, unbalanced networks, etc.... all of which are fairly common unfortunately for ranger and cutwater boats straight from the factory.
Best way to troubleshoot is to isolate the stereo be unplugging the nmea2000 cable at the back of the unit and see if it suddenly works fine, and if so then start troubleshooting the whole network to find the issue (...fun...). Next would be to update the software of all the units via a USB connected to the back of the unit along with making sure the Garmin system is fully up to date as well via a card or active captain.
i have the ms-ra210 in our boat and just had this issue. after reading through update notes, there is a software update that fixes it. i did the software update but i am not too gunshy to use the FM radio, i stream only and dont have a problem
Thanks. How did you install the software update? It looks like I have to remove the unit to access the back of it. Or, did you do it through the Garmin maybe? Thanks.
i actually did mine through the app. my radio was seriously locked and about once every 30 min would unlock for about 15 seconds which wasnt long enough for me to switch it off of FM on the headunit, but it was long enough through the app. Then i updated the unit through the app. very similar to updating the garmin suite, you just need the fusion app.
Thanks! It is frustrating to wait for it to work for a second or two and not get there in time to shut it off. 😀
It looks like this did the trick! Thanks! 😀
