Galley and Head Faucets
JeffreyAC77
2015 R31-CB (LE)
Lake Union, Washington
R-31 CB
FMLT3106E415
State of Mind
Does anyone have the actual manufacturer and part numbers for the faucets in the galley and head in a 2015 R31?
thanks.
We replaced the galley faucet with a head faucet. Aims the water down into the sink. If the faucets on your boat are interchangeable like ours are, you can switch them to see which you like best.
Barry Thompson
TOUCAN, R-27 Classic
Problem I have is the galley faucet has pressure to the hand held fixture (when I remove the fixture), but only dribbles out of the fixture when I put it back on......in the head - there is absolutely no pressure at all???
I don’t know if you have the same kitchen faucet with the pull hose and sprayer that we do but the problem you are experiencing is the same one we get every couple of years. Tried pulling out the screens on the sprayer attachment, backflushing and everything else I could think of the the sprayer remained plugged.
Finally just gave up and started replacing the sprayer attachment. The spray head screws into the existing hose. It’s a brushed nickel finish. Just make sure the threads are the same between hose and spray head. The model we use, which looks a lot like the original, is the Danco 10409 Pullout Kitchen Spray Head in Brushed Nickel. Runs about $25 to $35 at Ace Hardware, HomeDepot and Amazon. We carry a spare one onboard.
https://www.homedepot.com/p/DANCO-1-Han ... 47#overlay
If I remember from our call, you do have good pressure at the cockpit sink, which may provide a clue.
We have pressure in the head shower and the cockpit sink. Bought the Home Depot handle mentioned above but it was not the proper replacement for the galley sink - will now go to ITC to get a new fitting altogether. Not too concerned about the head sink at this point.
