Gunner065
- May 21, 2020
- C-26
- FMLR2516B010
- Off Watch
Evening all, about to acquire a 2010 R25 SC. I was able to put my hands on the electrical diagram and it shows some type of "Isolator". Can anyone confirm if these GI have fail safe capabilities?
I did some research on galvanic isolator and here's what I found:
"The ABYC standards for galvanic isolators have changed a few times over the years. The first iteration required “active monitoring“. This was in the form of a remote lighted panel so an owner could glance over and know they had a safe and operational GI with the safety ground intact. This “active monitoring” added significantly to the cost of GI’s and was a total PITA in terms of parasitic loads because it had to be “wired in” to more than just the green wire. It also created an issue with ELCI’s and GFCI’s as it “pulsed” the safety ground which could cause nuisance tripping.
A number of years ago a company called Dairyland Electrical Industries, or DEI for short, invented/brought the “fail safe” galvanic isolator to the marine market. This advancement brought simplicity, and no monitoring, back to the GI and did away with the lights and related circuitry. Unlike traditional diodes that tend to fail open the fail safely diodes fail closed and all you lose is galvanic protection. Today the ABYC standards require the use of Fail Safe galvanic isolators such as the ProMariner ProSafe FS30 or the ProMariner ProSafe FS60.
The designation FS or fail safe means that these devices fail closed instead of open as a normal diode would. By failing closed you only lose galvanic protection but not your SAFETY GROUND to shore.
Today companies such as ProMariner & DEI both make ABYC compliant galvanic isolators with the fail safe technology. Yandina & Sterling Power also make GI’s but they do not meet the current ABYC safety standards.
If you’re a mooring sailor who rarely stays at a dock the Yandina GI or Sterling Power GI can represent a value purchase but they must be routinely tested. If adding a GI, for regular dock side use, the author strongly recommended installing a fail safe product."
Any insight/thoughts on the matter? Since I will have the boat tied up at the marina and will be plugged to the jetty, is this something considering as an immediate upgrade?
