Scuffy
- Mar 5, 2015
- C-28
- FMLT27161
- Non-Fluid Motion Model
- Float On Tandem Axle Trailer
- Tinytown
I noticed a couple of gaps where things had disappeared. The first gap we noticed is behind the shelf in front of the helm. A metal deck key on a floating key chain disappeared down there. Retrieved easily enough through the door in the berth that accesses the area. I wondered about the metal deck key around the power connections. I slit a swim noddle and packed that in there. The second area that has a gap is the port side under the window just to the left of the wooden opening cave door. That area we discovered to missing paperwork. I was a little windy and the paper with the codes for the marina showers and Wi-Fi codes turned up missing. My wife noticed the gap and we took a fly swatter with some reverse duct tape and fished out about 50 ranger Tug brochures and the missing marina info. (Marc that why you kept running out of literature at the shows). More sliced swim noodle closed the gap. I did not see another way to access that area where the papers had disappeared into? Just a thought for the Factory that these areas might be closed off as I couldn't see any real purpose for the gaps. Not a criticism more of an observation.
D.D.
D.D.
