Garmin and Yanmar Connecting Cable
Jim and Jackie
C-288 C
FMLT2930C010
Chessie
Last fall I was having trouble with both the Garmin and Yanmar instruments. When they got them both working they separated the two backbones. On this forum I got a sketch showing how the two should be connected with a NEMA 2k backbone cable with the power lead disconnected. Does the factory have any of these cables?
Right now the Yanmar backbone is just a "Yanmar "T" with the engine cable ant the Yanmar instrument connected. The Garmin backbone is terminated on both ends.
Jim Demerest
Chessie 2010 R 29
Instead of taking an N2K wire and cutting power out of it, you can order a NMEA 2000 power isolator and install that between the Yanmar and Garmin backbone. You should be able to get these at most electronic stores.
Andrew, That's a lot simpler. Power isolator already ordered.
Thanks.
Jim Demerest
Chessie 2010 R 29
