Garmin autopilot
Jfrano
R-29 CB
June Sea
Anyone know how to switch back from nighttime mode to daytime. Turned unit on from prior
Nighttime use and could not read the display. Is there a display reset?
Joe
It's under Settings (via the Menu soft key). you can change the backlight.
Yes, the problem is when it in night mode, from the night before, in the daytime, I can’t read the display.
As I recall, once you “long press” the power button to turn it on, if you press the power button again normally one or two times, you will come to a lighted screen that will allow you to reset the backlight. For that matter, pressing the chartplotter power button a second time will also take you to a control screen where you can reset the chartplotter backlight (among other things); and to change the Volvo display backlight, you repeatedly press the lower right button to make it cycle through the brightness levels.
John
