Garmin GHC 20 autopilot blank screen
yorangerjim
FMLT2736J819
Ranger 27 northwest edition
R & R
Hello, My autopilot on my Garmin screen is blank I have replaced the batteries on the handheld the screen is blank however I can control the boat with the handheld. If anyone has a fix please
Thank you
Jim
Thank you
Jim
It's most likely not blank. The dimmer is most likely set to its lowest setting. Look at it while it's dark outside, all the lights off in the boat and hopefully you'll be able to see the screen so you can adjust the backlight to brighter.
I will try that out
Thank you
Jim
yogolferjim":210dxq5o said:
I will try that out
Thank you
Jim
Alternatively... if it's light out and you want to give this a shot.. I wrote this down for another boater last year who ran into the same problem.
1 Turn on the autopilot.
2 Click the center button
3 Click the right button 4 times
4 Click the center button
5 Click the right button 3 times
6 Click the center button
7 Click the right button 2 times
8 Click the center button
9 Click the left button up until you can see the screen.
Hopefully this fixes it for you.
I will try that Thursday and get back
Jim
