Marnis
- Mar 25, 2016
- C-302 SC
- Sonny Side Up
Hi,
Over the years I have read multiple postings regarding steering issues where the problem was leaking check valves. The problem in the majority of cases was corrected by a check valve kit provided by Garmin. When we purchased our 2018 RT31CB new, I had steering issues which were due to low steering fluid. Once topped up and bled, all appeared to function properly. Under autopilot we never had any issues with steering. Over this past season we were constantly correcting the steering one direction or the other when operating manually. When you would go hard to port or starboard it would appear to lock and then continue to loosen and you would have to keep turning the wheel. The system was bled and and checked for steering fluid level. All was correct. I feel know that the problem can be corrected by installing the Garmin check valve kit. In the multiple threads that I have read, some owners were fortunate to have Garmin do the installation at their expense and other owners had to pay out of pocket. How do I go about getting the service done with Garmin covering some or all of the expense, considering that this problem has been going with many owners for years.
Sonny
Sonny
