Garmin question
lone ranger
C-24 C SE
fmlt2135b808
TUG U
Hi,I need help with the garmin gps map 545s.the transducer seemed to gooey glued to the hull ,but I don't get depts on my screen.is there a special way to mount the transducer ?
Depending on your transducer it may be a cup glued to the hull with the transducer screwed in the top in the proper angle. The cup is filled with glycol or antifreeze as a transfer medium. At leastthats the way on my r27
The transducer in the R25SC is also mounted in a cup filled with antifreeze (-100 degree freshwater system antifreeze is what they generally use). Counter clockwise a quarter turn and lift and it comes off the cup that is glued to the hull. Hold it to your ear and if working it will make a slight ticking sound when on. If your unit works the same as the 741XS, there is a screen in the menu section of the sonar screen that turns the transducer on and off (which may have accidently unbeknownst to the user somehow got turned off).
Check the fluid level. Had the same issue and was due to a lack of anti freeze. Filled it up and all is good.
If the transducer checks do not reveal a problem, I offer another suggestion: If you have not deleted your "Active Tracks", then do so. It seems that storing too many Tracks uses memory that the depth sounder needs for processing, and the result -- at least in my case -- is that the depth display shows dashes. Deleting the stored Active Tracks and restarting the GPS unit (power Off/On) restored depth operation.
I am indebted to someone on TugNuts for this insight -- it was some time ago and was buried in an even more diverse helpful message, but I cannot recover the name for attribution. For reasons that I cannot comprehend, Garmin does not display a warning of the memory overflow, nor can I find any hint of the issue in their printed instructions.
-- John H
