tedli357":3uzrlbxd said:Hi Martin,
What app (apple) would you recommend?
I second this recommendation. I use Anchor Pro and boy is it loud!!! Definitely gets your attention which is the point.Submariner":19p0ckbe said:The Garmin will pull about 20 watts in standby, and 30 watts when on. That'll draw about 12 amps over 8 hours.
It's best to run an anchor drag app on your phone and turn off the Garmin chart plotter.
Alpina":2tbrzzot said:I second this recommendation. I use Anchor Pro and boy is it loud!!! Definitely gets your attention which is the point.Submariner":2tbrzzot said:The Garmin will pull about 20 watts in standby, and 30 watts when on. That'll draw about 12 amps over 8 hours.
