SGIDAVE":3g71mzes said:
Binare":3g71mzes said:
All 3 of those points deal with inproperly installed systems. Do it right in the first place and ALL those issues are avoided, accept for the lightening of course, in that case, your screwed anyways, if air is conducting electricity, so is damn near everything else your boats made of, a simple bond wont really matter.
Hello Bin,
When you say
The Bond is for safety, it should NEVER be electrically tied to anything, doing so defeats its purpose.
Your argument is really with the ABYC standard E11, specifically E11.5.5.1 and following where it states:
The main AC system grounding bus shall be connected to the engine negative terminal or the DC main negative bus on grounded DC systems
dave
The problem is that laymen read code and think they understand that code.
The DC grounding system, including your grounding bus is a non-current-carrying system. It is the exact same as the bond system in AC.
You need to understand the difference between a grounded conductor and a grounding conductor in order to understand the code, whether its in AC or DC, you do not.
Tying it in at the negative side of the DC maintains its non-current-carrying as its not part of any actual circuit unless there is a fault, it is the same potential as the AC bond system and is there as SAFETY.
If the positive side of a DC circuit fails and touches the metallic case of a piece of equipment, the grounding bus is there as safety to ensure a path of low resistance, low resistance equals high current equals tripped breaker. EXACTLY the same in an AC system.
Assuming you know these things and tying in DC equipment to the grounding bus, instead of the grounded (negative) bus is wrong and defeats the purpose of that safety, now the normally non-current-carrying metal parts of that dc system is carrying current it shouldn't be.
I am well versed on both ac/dc systems, my comment
Is 100% correct.
I suggest you read the code you are quoting and look for the definition of grounding, you will be surprised given your misunderstanding of the topic.
The 3 points you mentioned state tying in the AC bonding system with the DC negative connection, that is completely incorrect and misleading, and the code you mention agrees with me.
The AC bond system shall be tied into the DC grounding(bond) system, which is than tied into the negative side main bus. If I tie in the AC or DC bond into any other part of DC negative, and do not maintain it as a grounding system(tie in a negative conductor from equipment), it has become part of the negative bus and you no longer have a non-current-carrying grounding bus.
