nzfisher
- Jan 26, 2009
- R-25 SC
- Swims with Tuna
In replacing the inverter on my 2011 Rt25sc I noticed there is no ground wire coming off the low voltage end of the inverter (there never was one). The manual says there should be one in reinstalling the new inverter. I would like to believe there is some reason that the factory did not include this ground wire. I am looking for advice of those in the know about this issue. Please advise.
Also, as I have everything out of the lazarette starboard I would like to make a new manifold of copper elements to replace the distribution of water with clamps and fittings. I will add port for mixer valve and water outflow valve to purge system in a less “cobbled together” system. Any thoughts on using copper here? Again looking for advise. New manifold would reduce parts by at least 50% and joints by 75%. Thanks
Lastly I am replacing GH10 autopilot pump (third replacement) and spoke at length with Garmin. They had no thoughts about why the failures occurred and thought the hose configuration from factory was ok. From info from other tug members I am adding the asymmetric hydraulic attachment unit to the head of the pump nd am still considering the pressure relief unit that others have used. Looking for feedback.
Swims with Tuna
Swims with Tuna
