Heat
Tugboat Bob
FMLT2726C313
Passion II
Does my 2013 R27 have heat without turning on the engine?
If you are plugged in and have AC you can have heat.
The reverse cycle heat of the HVAC does a nice job. Pulls moisture out of the boat too. Works off a generator if you are at anchor.
If you don't have the HVAC you can also use a small heater. I have the Caframo. Running on low it consumes about 600 watts. Enough to take the chill off. You need an inverter to run this. While I have HVAC I often use the heater for a quick warm up.
-martin610
