Mastercraft
- Dec 4, 2020
- R-29 S
Question 1- cabin engine heater blows cold air only, why? Engine D4-300 is constant 185F. 15 amp fuse is good. I am going to see if it is due to slightly low volume coolant causing air in heater. I forgot to check to see if valve got accidentally shut off. Is there a maintenance manual for heater? If you got hot water and fan, it should work, correct?
Question 2 - there is a one amp fuse for Webasto heater remote, is this a remote control? Does anybody have a remote control for their heater? Did remote control possibly not be given to me from original owner? The heater thermostat in the cave is like putting your house thermostat in the hallway to your house garage or in your laundry room, not the best location.
Question 3 - I replaced the original Webasto rheostat with a $90 generic digital. It is much better but still terrible. There was a Webasto distributor in Seattle (name?) that I bought the generic digital from several years ago. They said that was my best option. It is + or - 4 deg and the buttons are very tricky to switch from “run” to “set”. What is my best option for another controller.
