Good morning.
Just took our 2019 29CB out for the first time for the season. Everything working fine except depth finder (will add antifreeze, is likely low and therefore needs to be filled) and hot water heater. Fresh water tank is filled, either engine on or genset on to run hot water heater, air seems to be pushed out of the lines, but no hot water yet, breaker is on, what is the procedure to get this system running? Cold water running fine.
Thank you
Thank you
