Brian B
- Apr 19, 2012
- C-26
- FMLR2512L910
- Non-Fluid Motion Model
- Sold in 2021
- GANSETT RANGER (2010) Yanmar 4BY2-150
Another Ranger tug owner who was at the SW Fl tug rendezvous in Jan gave me this idea and I finally got around to completing it. This is a Moen model 104465 mixing valve, it mixes the cold and hot water to a preset temp so you don't have scalding hot water coming out of the faucets. By removing the orange cap the temp can be adjusted, this was preset at 120 degrees. The 3 large brass fittings that are screwed onto the body are included with the valve. I found the hose barbed fittings that screw into them at Lowe's. The bottom fitting is a Pex as I couldn't find a 90 degree hose barb locally. A straight barb would also work but for my application I preferred the 90 as I also plumbed this into the cockpit Whale shower.
Use brass fittings, they sell plastic ones but they will leak.
I paid $40.80 for the valve on EBay and about another $25.00 for various fittings, clamps and a few feet of hose at Lowe's. The install is fairly easy and takes about an hour.
