it4llc
- Oct 18, 2020
- Arlington, VA
- C-28
- FML28C17K920
- Gremlin
I've been wondering how healthy our house bank is. We have not spent tons of time on the anchor, but a few of the times, when reading the unit voltage on the chartplotter, it is down to 12.2, which I understand is ~50% discharge. However, we were only anchored for at most 3-4 hours. A couple of those times, we started with a warm fridge, so I wondered if that could be draining the batteries. I also started turning off the chartplotter to conserve. This past weekend, starting with a full bank (according to the solar charger panel) we went out and anchored for a little less than an hour. We started with a nice cold fridge before we unplugged from shore power. While anchored, we had on the chartplotter, VHF, fridge, wine cooler (which also started cold), stereo, and used the fresh water wash for maybe 5-10 minutes. We had medium sun out, so the solar would have been putting a little into the bank. Using the battery usage calculate spreadsheet from FM, my rough math is that we would have used about 22 amp hrs, or about 10% of our bank, which would correlate to ~12.55 volts. However, the unit voltage on the chartplotter was showing 12.2.
So my question is whether the unit voltage gauge on the chartplotter can be relied on? Should I get the batteries tested? (We got our boat new in Nov 2020 so the batteries should have some life left, unless they got run down too far at some point.). Any advice or tips would be appreciated.
