psolie
- Jul 7, 2017
- C-242 C
- FMLT2319H617
- Sweetie Pie
Put in a new set of batteries 1.5 years ago from Battery Systems Seattle. In the last 2 months both house batteries, 2 weeks apart ,over heated bad and were smoking and the engine battery had only 340 cranking amps. Went back and got a new set, I have the new ones installed, charged them for less than 1 hour and meter showed the top line flashing on the meter and on the charger display it read: 14.4A, 21V, so I turned off the charger.
If the charger is working OK what read outs should I see on the charger and meter? Or do you suspect a problem with the charger?
Also What does the remote switch do?
Is there a battery temperature sensor installed on my boat, 2016 R 23 OB?
Thanks in advance, Paul Solie
