berniefiedler":3llq9nfo said:
So, from what I'm reading, running your Ranger in petroleum polluted water could shorten the impeller's service life?
One must assume so based on the warnings that are included with the new replacement impellers.
I would also suspect boaters who experience premature impeller failures fall into one or more of the following conditions
1) Run through dirty water
2) Run through water with fine sand particles suspended
3) Run to close to the sea bed for prolonged times
4) Have failed to open their thru hull valves too many times causing the impeller to run dry for short times
5) Run their engines at high RPMs for long periods of time exposing the impeller vanes to more stress/strain and many more impeller revolutions per mile compared to running longer time but at lower RPMs. I have to assume the raw water cooling impeller has an MTTF (mean time to failure) that is a function of the number of revolutions it makes before failing, ignoring all the other numbered items listed here.
6) Improper installation
7) Bad luck
8) Ingested small non-compressible objects through the hull's water scoop and passing through the raw water strainer such as pieces of wood and hardened plastic pieces.
9) Running boat through polluted waters with oil and petroleum based products suspended in the water.
10) Over the long haul the interior surface of the pump becomes grooved, pitted, scoured, rough etc placing undue stress on the impeller vanes
