Pretty sure the 2013 R27 came with salt water flush from the factory. Ours is a 2014 R27 with salt water flush. The big advantage of a salt water flush is the saving of your fresh water. A quick spray from your fresh water faucet can be used to help the flush or wash down the bowl if needed.
Unless your boat is modified, I suspect it will be salt water flush. If you have no issue with bad odors then don’t worry about it and enjoy your boat. If odor is an issue the it can be addressed via multiple means.
Holding tank vent filter (we have one, highly recommended) we built an in line charcoal filter, like this :
http://www.tugnuts.com/viewtopic.php?f=5&t=3921&p=29936&hilit=Waste+tank+filter#p29936.
Tank solution: We stick with the manufacturers solution (Raritan KO [knock out]).
Regular cleaning of the bowl and lines with the manufacturers recommended cleaner that is compatible with the tank solution (Do not mix dissimilar chemicals, many are designed to work positively with the bacteria/enzymes). Others just kill everything in the tank, which is a short term solution at best).
While I considered a fresh water flush at one time I am glad we did not go that direction. For long trips our fresh water supply is precious. Once we managed the initial odor via the above steps it has not been an issue for over 6 years.
I’m sure you will get plenty of opinions on this sensitive (and sometimes smelly topic!) . Hope this helps.
Curt
