acdfpic
- Dec 28, 2018
- C-26
- FMLR2525B414
- Destined Nomad
Due to the loss of my transmission on my RT 25SC with the D3 150 hp, I had to get towed in. I’m on the Great Loop in Michigan, and my first tow was by the Coast Guard in 3 to 5 ft seas. I have detailed this on the Facebook Tugnuts page, so I won’t go into all the details now. They towed me into a port without any repair facilities, and so it took a further tow to get me to the repair facility. We had to wait almost a week for good weather conditions, but finally had a 50 NM, 9-hour tow to get to Cheboygan, MI where I could get the transmission replaced. I’ve detailed the transmission issue in another thread.
After replacing the transmission, we went to start and it was immediately apparent that there was something wrong…wouldn’t turn over and just clicking. We suspected hydrolock right away. The injectors were pulled and sure enough there was water in one cylinder. It took a fair amount of time to get all the water cleared out of the exhaust system, but afterwards the engine started and ran fine. Stopping as soon as there was a problem was probably the key to not having any other damage. We also did an oil change before running the engine. If we find any evidence of water in the oil, we will do another change in a few hours.
So what caused the hydrolock? During the entire tow, the thru hull was closed. There was just about no wave action the day we towed her, so there probably wasn’t pressure enough to force water up through the exhaust. The only other water source was the cooling line to the prop shaft packing. It looks like with the prop slowly turning as it was being towed, that water might have been pumped up into the exhaust system. Looking at some old Tugnuts pages, it appears that some with the Yanmars have had this problem in the past. It may have been a function of the length of the tow as well. Just a little bit of water, over a 9-hour time frame can add up.
I hope that I never have to be towed again, but if I do, I will clamp the cooling line closed and tie the prop shaft off so that it can’t rotate.
Chris Boyd
2014 RT 25SC
Destined Nomad
Facebook Group: Destined Nomad
Chris Boyd
2014 RT 25SC
Destined Nomad
