Steeldieman,
I'm by no means a expert on fuel maintenance on- board . There are so many additives out there to purchase that you have to research to find out what people use, what works and what doesn't . For diesel fuel make sure it doesn't have alcohol in it and research its compatibility to common rail components. I use PRI D so far it has worked and I haven't had issues. PRI D claims it can restore old fuel.??? In your situation I would research an additive, put it in your tank, launch the boat ,start the engine run it for a while , drain the Racor filter, inspect the fuel for water and debris. Then pull the filter and inspect it for dark color staining and debris. Most likely your not going to find anything but if you do, there are test kits available for testing your fuel for water, algae, and microbes. Do a search and research what you feel is the best kit. If its bad which I doubt it is . Purchase a biocide ,put it in your tank and then polish your fuel. Keep a couple extra filters on board just in case. You never know when your going to pickup some bad fuel when boating. You most likely have nothing to worry about but its good to stay on top of preventative maintenance on the boat.
Brian Brown
Cutwater 26
PORT-A-GEE
