Impeller change question Volvo D4
GZigmont
C-302 SC
Jack
Do you actually have to disconnect the belt on this engine to install the new impeller as it says to in the owner's manual? I haven't had to do that on any of my Yanmar diesel engines on my sailboats. Please let me know your experience.
Thank you!
On the D4 300, you do not need to remove the belt to replace the impeller.
On this D4, the plate which has to be removed to access the impeller faces to the rear of the engine. The belt is on the "front" side of the water pump, and does not have to be disturbed.
Thank you. That is what I thought, but there is always something you don't know.
Thank you!
How long has the impeller you want to replace been in place ? Just curious about this. Maybe you're doing it per the maintenance schedule?
When you do pull the old impeller out, post back if you see any impeller damage.... thanks. 🙂
My personal rule for years has been to replace the impeller annually and keep the used one as an emergency spare if it’s in good shape. I view my schedule as cheap insurance. Just MHO.
If it doesn't slip right out just bump the starter with the cover plate removed.
I had a really hard time getting mine out. I will try your trick next time.
Agreed. My generator had 12 hrs when I purchased the new to me boat. Had it shut down on me a few times. Wasn’t sure what was the cause. After confirming oil levels, etc. I took the impeller out and saw this. I counted all the parts and non made their way into the cooling circuit. The previous owner likely ran it with the peacock closed at some point. As you said, cheap insurance.
I replaced the impeller on my D4 last January at about 150 hrs. It was in perfect shape, so I’ve kept it as a spare. I didn’t need to disconnect the belt. But I wasn’t able to pull it out manually. I knew about the “bump the starter” technique, but it didn’t work for me (I may have been too tentative with it, and I was doing the work on my own, without someone else to give the starter a bump). I decided to invest in a Sea Dog puller for it, which was a modest expense and is now in my special waterproof box of impeller replacement parts and tools. I rationalized the cost by telling myself if I ever needed to replace it on the fly in bouncing seas, I would want the quickest, easiest means of replacement. For me, that was an impeller puller (as a 67 yr old woman, I’m not too proud to say that my upper body strength is not what it used to be).
My hunch is that the manual says to remove the belt so that the impeller turns freely by hand. Which would make it all the easier to remove and install. But loosening and tightening the belt would offset that benefit. For me, I’d rather leave the belt in place and use the impeller puller to easily and quickly make the change out.
Either way, routine replacement of the impeller is a good drill for maybe having to do it in more emergent circumstances. So I plan to do it annually.
Gini
