Indicator light at switch won’t go out
Havinfun
Seaswirl Spyder RS
Tuggin Fun
So today when shutting electronics down on ‘16 27 Classic I noticed the autopilot screen would remain on. Normally when the Chartplotter and NEMA breaker switches are flipped off, everything goes off. Now the light adjacent the NEMA breaker stays on, the autopilot screen stays on, and the CCU also stays on. Can manually turn off the autopilot but how to turn off the CCU?
More importantly, why is the indicator light staying illuminated on the 12 volt panel with the switch off, and what caused this to start?
Check your Fusion Stereo settings. Make sure NRX is off. If on it can put power to the N2k bus.
Curt
That was it. Thank you.
Great! It took me awhile to figure that one out when I had the same symptoms! :geek:
Curt
