AK KRUEGERS
- Apr 30, 2021
- C-30 S
- WATER WITCH
This is a long shot...
Looking for information/suggestions for a permanent install on the Starlink Gen 3 cable on our R29.
We use the unit only while in our slip in the harbor and not while underway. This summer we came up
with a temporary solution of running the cable from the forward rail aft to the area above the aft freezer.
This worked OK with the exception that anytime we headed out for the day and to stay away from the
"Mobile Priority" cost, we were having to unplug the power brick and the router and storing in the cabin.
Ideally I would like to have the cable routed to an area in the cabin and a power supply with a switch to
disconnect power rather than always having to unplug the cables.
Since we travel with the unit, the components need to be easily accessible for removal but I've purchased
another cable for that purpose..
Looking to see if anyone has installed just the cable and added a power switch.
Thank you!
Thank you!
