Tug-N-OK
- Apr 25, 2016
- C-24 C SE
- FMLT2108H910
- Tug-N-OK
My captain Ken passed from this life 18 months ago so I am now solo on my R21EC. I remember that he told me freezing weather was hard on the HydroHoist lift so I take my tug out whenever the temperature is above 40 and the wind less than 15, which is several times a week. It is my solace. There are no marine diesel mechanics on our lake but fortunately Tim who assisted my husband is still available to help me.
Last November I ran over a nylon ski line that wrapped around my propeller so tightly that Tim had to remove the prop to get it loose only to discover 3 of the 4 blades on the propeller were bent and the propeller anode missing; however, the driveshaft looked OK. While the prop was sent to Propellers by Nettle in Texas for repair, I decided to see if there was any preventive maintenance that should be done. Was there ever… it is apparently not enough to just add fuel and occasionally check the oil! I am constantly learning all the things Ken did that I didn’t even see. When Tim tried to remove the gearbox dipstick, it was on so tight that it broke and the oil was so low it didn’t measure on the dipstick. We replaced the oil and dipstick. When the prop was returned (it looked great!), Tim had to bore the replacement zinc because it didn’t line up. There appeared to be no problems in neutral or low rpm, but when I took my tug out, I heard a high pitched whine at higher rpm. I must admit that I had not been aware of the sounds my engine made before this experience so do not know if that whine had always been there. He removed the propeller zinc but still had the whine. He found 4 13mm bolts from the shaft to motor were loose as well as the belt and tightened them. It now only whined at about 2100 rpm. Since I had the same whine with or without the propeller zinc, he replaced it.
I was back in business for several months, just choosing to go at less than 2100 rpm. Then in early March when I put the tug in gear to pull out of the slip, I heard a long thumping sound and immediately put it in neutral. Tim happened to be on the dock, so we lifted the tug out of the water and sure enough I had bent my prop again, just 2 blades this time. Although they do an excellent job, Propellers by Nettle do not offer a frequent bender discount! Apparently the tailwind had pushed my tug forward so that the prop caught on the boatlift supports. I now push the tug to the back of the slip to be sure the prop is clear before I put the engine in gear! Since weather in Oklahoma can be unpredictable, I winterized my tug and sent the prop off to be repaired.
I had to have surgery so was unable to take my tug out for over a month. When I could finally take her out, it was a beautiful day and I was so excited that I forgot I had winterized her and did not check the seacock (it was closed) and even worse, did not check that water was coming out. I had been out quite a while when I noticed the Overheat light was on, I never heard an alarm. I made another mistake: I turned around and headed home instead of immediately turning her off. I did call Tim to alert him that I would need some help. He had me stop the engine, wait 15 minutes, and then try to start it again. The engine started but the light came on immediately. He had me stop the engine and came to tow me back to the dock. The impeller was badly damaged, melted and possibly some pieces missing, but the oil was clear so he felt I had not done serious damage. He replaced the impeller. When I took her out again, I noticed an intermittent whistle and whine. Tim believes the sound is coming from the impeller area. He removed the impeller and verified that it was inserted the correct direction and used more glycerin, but the intermittent whistle or whine remains, never in neutral but at different rpm.
I’ve looked through the posts and am concerned that pieces of my impeller may have gotten into the heat exchanger. I carefully watch the overheat light now and have had no further problems. Since there is no marine diesel mechanic to check my tug, what do you recommend that I do?
