Inverter Question
pdo
C-288 C
Selah
I have a new 2024 C288 with the lithium batteries. When I go off shore power to inverter the hot water heater will no longer work. Everything else operates fine, other than the hot water heater. I understand that the hot water heater is a big energy draw, so I normally turn all other things like AC off when turning the hot water on. Can someone give me some guidance as to the cause and solution to this? Thanks for the help!
