Mastercraft
- Dec 4, 2020
- R-29 S
Problem: Inverter won’t turn on - PLEASE HELP - ANY ADVICE
- Microwave, galley, outlets fwd, and salon outlets won’t light up on breaker panel
- Volts on 3 batteries read 12.6 on panel. Should be 13.6 if charging?
- Outlets on inverter won’t work
- Don’t know if batteries are charging
- ABSO display in cave is stuck on R2.0
Info:
- Ranger Tug R29 2017 Northwest Edition (No AC)
- Plugged into shore power 15 amp
- ABSO inverter 2000
- 24v at inverter 2000 input
- Tried to reset everything - turned off four rotary switches (house, inverter, parallel, engine) and unplugged shore power for 5 minutes
- Problem happened when unplugged shore power for a minute. Problem often happened when connecting to shore power but would be okay after multiple reset tries.
- Boat is semi-live aboard and been using the same shore power for a year
Info:
