Osprey
- Nov 15, 2011
- C-28
- Osprey
This post is about thruster shear pin replacement on an R27 which has been in use since late 2011. Approaching the dock at the end of a 2 week trip the brass shear pin for the front thruster failed. The failure was simply due to normal “wear and tear”. The next day I pulled the thruster and replaced the pin. I was pleased to find that the job was easy to do. Keeping “easy” in mind I then thought that if the front pin failed could the rear pin be in need of replacement? Cannot be that hard I thought, so I better attend to the rear pin. Now I know why there have been many posts that indicated that “easy’ does not apply for the rear thruster. The found that the “how to” comments in these posts most useful – thanks Knotflying, doke01 and others. I have a printout of a 2016 post which has an image of Knotflying sitting in the propane locker. He does not look happy. I can now fully understand why!
And yes, the rear pin was ready to fail. How long have the thrusts on your tug been in service? What is the expected service life for these brass pins? For replacement I used the now available steel pins. Steel pins are common for outboard motors. Over the about 60 years of my boating experience I have replaced a few outboard steel pins. Replacement was always due to the propeller hitting something, not due to “spontaneous” failure.
