Fisho
- Aug 11, 2018
- C-24 C SE
- USFMLT2106F
- KHUNYAI
A couple of weeks ago my JABSCO remote controlled search light on 21EC stopped working completely. No light. No movement. Investigated replacing parts such as controller in cabin or power boat inside light but very expensive. Tested controller on advice from local JABSCO agent and it was working ok. Powered the light globe from separate 12 volts and it was working. Checked the motors the same way and they were ok. Some of the wiring on roof of cabin looked suspect and was bare so replaced it. Still not working? Tracked problem to poor connections inside the light from the three wires from the controller to the power board. Removed, cleaned and replaced connections. Reassembled the light and all working. So if you are having problems check the connections inside the light first. A bit difficult to take apart but once you remove the glass light and globe the inside just slides out. Just a bit tight.
